  3. Extract hierarchy tree data into csv file
  • Subscribers 150
  • Views 7846
Vascocsav
Vascocsav over 2 years ago
Hi to all,
My programing language skills are very limited so I wander if there is any way to retrieve the hierarchy tree data from a schematic or layout and save it as a csv file ?
thank you and best regards
Vasco
  • RobMan
    RobMan over 2 years ago +1
    Edit -> Hierarchy -> Tree Valid for both schematic and layout. It's note a csv but you can probably postprocess or import into a spreadsheet to convert.
  • AurelBuche
    AurelBuche over 2 years ago +1
    Hi Vasco, If you use the script from my answer in Cadence Community - Custom IC SKILL - Skill code to Get all the lib and views used in cell from top to bottom hierarchy You can then use the following…
  • RobMan
  • AurelBuche
    Hi Vasco,
    You can then use the following function :
    (defun cst_print_hierarchy_to_csv ( @key  (cv  (geGetEditCellView))
                                              (csv "/tmp/$USER.example.csv")
                                        @rest _)
      "Print CV hierarchy to CSV"
      ;; Support variables and relative paths in csv
      (setq csv (simplifyFilename csv))
      ;; Properly open and close port
      (let ((port (outfile csv)))
        (unwindProtect
          ;; Print each line
          (foreach lcv (cst_flatten_hierarchy cv)
            (destructuringBind (lib cell view) lcv
              (fprintf port "%s,%s,%s\n" lib cell view)
          (close port)
      ;; Open csv in text viewer
      (view csv)
      ;; Return path of generated csv
      csv)
    Cheers,
    Aurélien
