  3. viaGenerateViasAtPoint Auto via function help
  • Subscribers 150
  • Views 6879
mattab
mattab over 2 years ago
How can I restrict   viaGenerateViasAtPoint to add  auto-via of only one type of via
For example even if there are  met1 ,met2,met3 overlapping at one point ,I need to add only via between met1-met2
Thanks for the help in advance
  • RobMan
    RobMan over 2 years ago
    Please try this...
      Create -> Via (or 'o' bindkey)
      'F3' for Command Options
      On the Command Options from there is an additional 'Options' button. Click this.
      Then disable the vias you wish to exclude.
  • RobMan
    Then I realise you are using SKILL... Try this:
    techFile = techGetTechFile(ddGetObj("gpdk045"))
    constraintGroupId = cstFindConstraintGroupIn(techFile "virtuosoDefaultSetup")
    myViaOptions = viaGetViaOptions(constraintGroupId)
    viaGenerateViasAtPoint(cv list(25 25) myViaOptions ?topAndBottomLayers list("Metal2" "Metal1") )
    Substituting techfile, location and layers as appropriate.
    Potentially an option to setup a Constraint Group too but that's a bit more work.
