  3. Changing from one metal layer to another metal layer
  • Replies 10
  • Views 9714
STrib
STrib over 2 years ago
Can someone please provide the code to change one metal layer to another metal layer within the prBoundary
  • RobMan
    RobMan over 2 years ago +2
    Is this something you wish to do repeatedly or just a one-off? If it's a one-off I'd just use the ui.
  • AurelBuche
    AurelBuche over 2 years ago in reply to STrib +2
    Sorry, but this is not a forum for custom SKILL deliveries... Try to do it by yourself and if you have questions about your code, I'll be happy to answer them
  • STrib
    STrib over 2 years ago in reply to RobMan +1
    I would like to change the metal layers inside the PR boundary only. Like outside the PR boundary I dont want to change the layer
  • RobMan
    • Vote Up +2 Vote Down
  • STrib
  • RobMan
    RobMan over 2 years ago in reply to STrib
    That doesn't answer the question.
    N.B Area select entirely feasible.
    This thread from a previous question goes part of the way...
    Skill code to copy object to another metal layer but maintain the objects purpose - Custom IC SKILL - Cadence Technology Forums - Cadence Community
  • STrib
    I would like to do it repeatedly and moreover one thing we can do change change metal layer "X" to metal "Y" within a specific area (coordinate location)
  • AurelBuche
    You could use ABE (Advance Boolean Engine) but this will require your layout to be flattened
    1. Extract the metal, using:
    abeInit, abeLayerFromCellView
    2. Create a boolean layer for the prBoundary, using:
    abeNewLayer, abeLayerOrPtArray
    3. Make the AND operation between boundary and metal:
    abeNewLayer, abeLayerAnd
    4. Generate the new metal :
    abeLayerToCellView
    5. Chop remaining metal shapes
    Use abeIslandIterator, Flatten the layout inside, then delete shapes using the island points and leChopShape
    6. Close ABE
    abeDone
  • STrib
    STrib over 2 years ago in reply to AurelBuche
    Thanks for the explanation ,
    Can you please provide a code for that
  • AurelBuche
  • STrib
    I am able to do it now and one last doubt ,if I want to change a particular metal layer from one to another outside the PR boundary then how can I proceed?
  • STrib
    STrib over 2 years ago in reply to STrib
    Basically I am facing issues in deleting a particular metal layer outside PR Boundary.
    I shall be grateful to you if you kindly help me regarding this
  • AurelBuche
    This is almost the same thing as inside
    The trick is to work with an ABE layer that is defined using prboundary and cellview bbox
    (let ((abe_cv               (abeNewLayer))
          (abe_inside_boundary  (abeNewLayer))
          (abe_outside_boundary (abeNewLayer))
      ;; Define cellview bounding box layer
      (destructuringBind ((x0 y0) (x1 y1)) (geGetEditCellView)->bBox
        (abeLayerOrPtArray (list x0:y0 x1:y0 x1:y1 x0:y1) abe_cv)
      ;; Define prBoundary layer
      (abeLayerOrPtArray (geGetEditCellView)->prBoundary->points abe_inside_boundary)
      ;; Define not prBoundary layer
      (abeLayerAndNot abe_cv abe_inside_boundary abe_outside_boundary)
    Cheers,
    Aurélien
