  3. enterBox() used to option form
  • Views 5101
Yush
Yush over 2 years ago
hi,
I 'm confused about the post: community.cadence.com/.../how-to-store-values-for-the-form-fields
1. is there any ways to keep not display the form when commands repeat?
2. When I replace the button with ApplyHideCancel, does the program execute as:
    testDoneProc(win done bBox)   =>   done -> t  ;  bBox  ->  nil
the code copied from the above post:
procedure(testDoneProc(wid done box)
  ; don't do anything if cancelled
  when(done
    printf("%L\n" box)
    if(optionsForm->Type->value == "type1" then printf("%L\n" car(box)))
    if(optionsForm->Type->value == "type2" then printf("%L\n" cadr(box)))
    ; enterBox doesn't seem to honour modalCommands itself ("Repeat Commands"
    ; on the Editor Options form) so achieve the same thing
    ; by enqueuing the original command again
    when(envGetVal("layout" "modalCommands")
      hiEnqueueCmd("test()")
procedure(test()
  let((optionsForm box)
    cv=geGetEditCellView()
    ; Only create the form if it doesn't exist already; always
    ; stored in a global variable, so make sure the name is unique
    unless(boundp('CCFuniqueOptionsForm)
      ; hiCreateAppForm has more control than hiCreateOptionsForm
      hiCreateAppForm(
        ?name 'CCFuniqueOptionsForm
        ?formTitle "Options"
        ?formType 'options
        ?fields list(
          hiCreateRadioField(
            ?name 'Type
            ?prompt "Type"
            ?choices list("type1" "type2")
          );end Type
        );end list
        ; Control buttons and initial form size
        ?buttonLayout 'HideCancelDef
        ?initialSize 300:60
      );end optionsForm
    optionsForm=CCFuniqueOptionsForm
    ; Moved the processing into the doneProc
    box = enterBox(
      ?form eval(optionsForm)
      ?doneProc "testDoneProc"
  );end let
);end procedure
hiSetBindKey("Layout" "<Key>z" "test()")
