  3. Showing list of history name and its notes for similar history...
  • Views 6462
Showing list of history name and its notes for similar history name at ADE Assembler
HongJian
HongJian over 2 years ago
(+) Virtuosity: Exploring Histories - Analog/Custom Design - Cadence Blogs - Cadence Community
This is taken from the blog post. Is it possible to do it at ADE Assembler level? (SKILL solution is welcomed too)
I need to run on ADE Assembler instead of ADE explorer for comparing variables/setup state.
    You can see the notes as a tooltip in the history tab of the Data View assistant - is this what you want? My first rule is don't write SKILL for something that already exists (if it's close enough)!
  • HongJian
    HongJian over 2 years ago in reply to Andrew Beckett
    Hi, just a follow up, the notes that i keyed in inside the Specify History Name form is missing and I need to rekey the same note after the run is finished. is this expected?
    the note is missing
    Andrew Beckett over 2 years ago in reply to HongJian
    This appears to be a bug with the older way of setting the history name prior to simulation: envSetVal("adexl.historyNamePrefix" "showNameHistoryForm" 'boolean t)
    There's a newer way in Assembler with a toolbar to set the history name. That however doesn't have the ability to set notes - that's Cadence Change Request #2696580 which is requesting this. I suspect the older and newer history name mechanisms are interfering with each other and the note setting part has broken (it's certainly broken in IC23.1 ISR9).
  • HongJian
    I see, so it is known bug. I will write the note after the run is launched then. Thanks a lot!
    No, it's not a known bug (as far as I am aware). I reproduced it, but I didn't find any reports of it. You should report it to customer support.
