  3. Set "color" (double-patterning) of a metal in a PCell
  • Replies 9
  • Views 4144
Aldo3
Aldo3 over 2 years ago
Is it possible to set the "color" of a double-patterned metal in a PCell?
Thank you
Best regards
Aldo
  • RobMan
    RobMan over 2 years ago in reply to Aldo3 +1
    Do you mean 'dbSetShapeColor'? 'dbSetLayerColor' is not a valid function.
  • GL20241006666
    GL20241006666 over 2 years ago
    Hello Aldo,
    Yes, it is possible to set the "color" of a double-patterned metal in a PCell. This process typically involves using specific commands in the PCell's SKILL code to assign the desired color to the metal layers. The exact method can vary depending on the design tools and the specific requirements of your project.
    For instance, in Cadence Virtuoso, you can use the `dbCreateLayer` and `dbSetLayerColor` functions to define and set the color for different layers within your PCell. You might also need to ensure that your design rules and constraints for double patterning are correctly implemented to avoid any conflicts.
    Best regards,
    Aldo,
    Are you asking how to do this if you are developing the PCell, or are you asking where you have instances of existing PCells (which you can't edit) and want to set/lock the colors from above on those instances?
  • Aldo3
    Aldo3 over 2 years ago in reply to Andrew Beckett
    Hello Andrew,
    I'm writing code for a pcell that create metal shapes of both colors mask1 and mask2, and I would like to have the chance to set color for each shape in the pcell itself
    e.g. rectA = dbCreateRect(...)
           assign mask1 color to rectA
    Thank you
    Best regards
    Aldo
  • Aldo3
    Aldo3 over 2 years ago in reply to GL20241006666
    Thank you,
    Where could I find info on dbSetLayerColor? I tried to search in sklayoutref.pdf, without finding it
    Best regards
    Aldo
  • RobMan
    Andrew Beckett over 2 years ago in reply to RobMan
    I had an idea that the response that suggested dbSetLayerColor might have been LLM-generated... but I couldn't be certain whether that was the case or whether it was just a typo!
    Andrew Beckett over 2 years ago in reply to Aldo3
    That would be dbSetShapeColor...
  • Aldo3
    Aldo3 over 2 years ago in reply to RobMan
    Thank you
  • Aldo3
    Thank you Andrew
