  3. "Impact of Using Polygon Function Instead of Rectangle Function...
  • Subscribers 150
  • Views 1908
"Impact of Using Polygon Function Instead of Rectangle Function in Cadence PCELL"
thiruvenkata
thiruvenkata over 1 year ago
I was previously using separate procedures to draw rectangles and polygons in my PCell script in Cadence SKILL. Since a rectangle only requires two points, while a polygon requires four, I decided to simplify my code by removing the rectangle procedure and using the polygon function to draw rectangles instead. Will this change have any impact on the PCell generation time or functionality in Cadence Virtuoso?
I know, it may sound silly.
    Andrew Beckett over 1 year ago +1
    I don't quite see how replacing your rectangles with polygons simplifies the code (it's not simpler...) but potentially there's a (small) performance/memory/storage impact. Rectangles are more lightweight…
    Andrew Beckett over 1 year ago in reply to thiruvenkata +1
    PVS and other verification tools won't care whether it's a polygon or rectangle; they wouldn't see the difference. Andrew
    I don't quite see how replacing your rectangles with polygons simplifies the code (it's not simpler...) but potentially there's a (small) performance/memory/storage impact. Rectangles are more lightweight than polygons because you only need to store 2 points versus at least 3 (or 4 in the case of a rectangular polygon) - plus they have to cope with a variable number of points. I've not done any analysis on the impact (because the difference would be small in any case with a small number of objects), but the key point here is that they are different objects in the database.
  • thiruvenkata
    thiruvenkata over 1 year ago in reply to Andrew Beckett
    Thanks for the reply!!
  • thiruvenkata
    Let's say If I draw a rectangle using polygon API, if I run some DRC rules related to rectangle checks(like rect_chk), will PVS or other verification tools consider it has rectangle or polygon?
