  3. exit(1) function not found ??
  • Views 1016
nmz787intel
nmz787intel over 1 year ago
following this post:   how to get exit code !=0 when there is a skill error in a skill script?
I have this code:
(defun nestedFunction ()
(printf "Inside nested function\n")
(exit(1))
(printf "This will not be printed\n")
(defun mainFunction ()
(printf "Inside main function\n")
(nestedFunction)
(printf "This will also not be printed\n")
if(errset({
(mainFunction)
} t) then
exit(0)
else
exit(1)
and when I run it, I get this output with an error:
\o Inside main function
\o Inside nested function
\e *Error* eval: not a function - exit(1)
so apparently the "exit" function has been deprecated? What is the recommended way to kill a script with a particular returncode?
    No, it hasn't. The error is saying that exit(1) is not a function. If it was an undefined function, the error would have been:
    *Error* eval: undefined function - exit
    The problem is that you have (exit(1)) - you have a list inside the function call - and it's the list of (exit 1) or exit(1) that isn't a function. Extra matched parentheses cause a problem with SKILL, mainly because of the mix of C-style and Lisp-style function calls - the flexibility of different ways of calling functions causes some inflexibility when additional parentheses are given.
    You need to either have:
    (exit 1)
    or
    exit(1)
    not
    (exit(1))
