  3. ADE Parameters : mapping DPAR <-> device parameter in A...
  • Replies 9
  • Views 5865
ADE Parameters : mapping DPAR <-> device parameter in ADE
kkdesbois
kkdesbois over 1 year ago
When I use Parameters in ADE, I can see in the netlist that the parameters I set are transformed in DPAR_1, DPAR_2, ...
Is there a way to know the correspondance between the parameter DPAR_ in the netlist and the device parameter I set in ADE?
Laurent.
    Laurent,
    Not as far as I know, other than looking in the netlist where they are used.
  • kkdesbois
    kkdesbois over 1 year ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your response.
    I intend to address this issue differently by parsing the netlist.
    To do so, my code utilizes the function maeCreateNetlistForCorner to generate the netlist.
    However, the output netlist does not include the DPAR parameters, unlike the netlist generated for simulation when running ADE.
    Could you please advise if there is a way to generate a netlist that contains the DPAR parameters?
    Laurent.
  • kkdesbois
    kkdesbois over 1 year ago in reply to kkdesbois
    Hello
    I’m following up on this post in case my last message was missed during the holiday period.
    Laurent.
    Andrew Beckett over 1 year ago in reply to kkdesbois
    I don't think there's any public API to do this. What is probably needed is a public equivalent of the private function used underneath the Right Mouse→Create Netlist in the Run Preview tab, but this doesn't exist as far as I can tell.
  • kkdesbois
    That's a pity!
    Thank you, Andrew, for the clarification
  • kkdesbois
    kkdesbois 11 months ago in reply to kkdesbois
    As suggested, I opened a couple of weeks ago a CCR requesting a public function that generates a netlist with the parameters DPAR_.
    Anyway, I'm updating the post with another question related to the function maeCreateNetlistForCorner.
    This function generates a netlist as if we were in Assembler. This means that parameters in the netlist are those defined as Global Variables if they exist; otherwise the ones defined as Design Variables.
    I'd like my netlist to be created as if I were in Explorer, i.e without using the global variables.
    Is there a function for that?
    Laurent.
    Andrew Beckett 11 months ago in reply to kkdesbois
    Hi Laurent,
    I don't think there's a simple way of doing this. However, the following should do what you want:
    testSess=maeGetTestSession("TRAN_AC") ; could pass ?session if needed
    asiNetlist(testSess)
    view(strcat(asiGetNetlistDir(testSess) "/" asiGetSimInputFileName(testSess))) ; or just retrieve the file name if you don't want to view it
  • kkdesbois
    kkdesbois 11 months ago in reply to Andrew Beckett
    Thank you Andrew for the tip.
    I have never dared to use the function asiNetlist because, as stated in the documentation:
    This function is called by the environment, so you should not call it directly from the interface. This function can be redefined for the interface. Use callNextMethod in this definition.
    What does mean "so you should not call it directly from the interface"? Not clear for me.
    Laurent.
    Laurent,
    Whoops, I should have read the manual (I only looked in the finder for the interface, and didn't go further).
    The only public API that I can see which is "safe" is to:
    testSevSess=axlGetToolSession(axlGetWindowSession() "TRAN_AC")
    sevNetlistFile(testSevSess 'create)
    which always displays the netlist (actually it doesn't for all simulators, but it does for many). You can't override that.
    Or you could execute the flowchart (this ought to be OK too)
    asiExecuteFlowchart(testSess 'asiComposeSimInput)
    the flowchart steps can be found using asiDisplayFlowchart.
    However, there's a certain amount of caveat emptor here; you kind of want something similar to createNetlist() - an OCEAN function - but that requires the setup to be defined in an OCEAN session - i.e. the design(), analysis() etc. It's not obvious to me how generally useful it would be to produce this generic netlist (which is a bit of a hangover from ADE L).
