  3. Script to select all the shapes connected to a pin
  • Views 5706
Ganesh B
Ganesh B over 1 year ago
Hi, Is there any way to select all the shapes connected to a pin in layout using Skill  script?
    Assuming that the layout has connectivity (e.g. was done in Virtuoso Layout Suite XL), then maybe this is what you want? The idea is that you select the pins, and then call abSelectWholeNet() will then select everything on the nets for those pins.
    /* abSelectWholeNet.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 16, 2001
    Modified   Feb 26, 2009
    By         A.D.Beckett
    Updated to work with layout in CDB, where vias are instances with instTerms
    on the net; in OA vias are directly attached to the net.
    SCCS Info: @(#) abSelectWholeNet.il 02/26/09.14:08:25 1.2
    * (abSelectWholeNet @optional (cellView (geGetEditCellView)))  *
    *   Select the whole of each net that is partially selected.   *
    (procedure (abSelectWholeNet @optional (cellView (geGetEditCellView)))
      (let (nets theNet)
           (foreach shape (geGetSelSet cellView)
                    (setq theNet (dbGetq shape net))
                    (unless (member theNet nets) (setq nets (cons theNet nets)))
           (foreach net nets
                    ; Find all the figures on the net
                    (foreach fig (dbGetq net figs)
                             (geSelectFig fig)
                             ) ; foreach fig
                    ; Find all the vias on the net - only do this in CDB
                    ; when leIsContact function exists
                    (when (isCallable 'leIsContact)
                      (foreach inst (dbGetq (dbGetq net instTerms) inst)
                               (when (leIsContact inst)
                                 (geSelectFig inst))
                               ) ; foreach inst
                      ) ; when
                    ; Find all the pin figures on the net
                    (foreach pin (dbGetq net pins)
                             (foreach fig
                                      (or
                                        (dbGetq pin figs)
                                        (list (dbGetq pin fig))
                                      (geSelectFig fig)
                                      ) ; foreach fig
                             ) ; foreach pin
                    ) ; foreach net
           t
           ) ; let
      ) ; procedure
  • Ganesh B
    Ganesh B over 1 year ago in reply to Andrew Beckett
    Hi Becket, Thanks for the quick reply.
    Looks like the script works only if the layout is annotation clean. It doesn't work if the layout doesn't have the connectivity.
    Ganesh
    Andrew Beckett over 1 year ago in reply to Ganesh B
    Ganesh,
    You could run lceExtract(geGetEditCellView()) to run the connectivity extractor, and then use the code?
  • Ganesh B
    Hi Becket, Thanks for the reply. Extract Connectivity doesn't work in few cases especially when the devices are not bounded properly, is there any way to select the shapes which are physically connected to a pin rather than going with the net names?
    Ganesh
    Hi GB20250109498,
    Not really. There's lntAddTrace() (in "physical" mode) and leMarkNet(), and you can save the resulting shapes to another cellView, but these don't offer the ability to select the shapes traced (partly because they can traverse the hierarchy, so selection wouldn't be very useful in general - although lntAddTrace() could stop at stopLevel=0). You could either use lntAddTrace and then save this to another cellView and then use the resulting shapes with dbGetTrueOverlaps to find the source shape in the same place for each shape, or write your own shape tracer (more work).
    There's not really (that I can think of) anything that does this that is built-in.
    Even though lceExtract will have problems with instances that aren't bound, I would have thought it would trace the nets properly - so it may be better than nothing.
