  3. How to restrict net renaming to specific cell instances...
  • Subscribers 150
  • Views 2847
How to restrict net renaming to specific cell instances in layout using SKILL?
AR202509246930
AR202509246930 11 months ago
I'm using a SKILL procedure to rename power and ground nets (vnn! to vnn, and vpp! to vpp) for instances in my layout. The layout contains three cells: "a", "b", and "c". I want the renaming to apply only to instances of cells "b" and "c", but my current code is also applying changes to "a" unexpectedly.
I suspect the condition is not filtering correctly. Could someone help me correct the logic so that the renaming only applies to "b" and "c"?
I'm using cadence virtuoso 23.1 version
Thanks in advance!
Code:
procedure(renamepwrandgrndnets()
let((cv instTerm netObj netName)
cv = geGetEditCellView()
foreach(inst cv~>instances
when(or(equal(inst~>cellName "b")
equal(inst~>cellName "c")
printf("Checking instance: %s\n" inst~>cellName)
instTerm = inst~>instTerms
foreach(term instTerm
netObj = term~>net
netName = netObj~>name
printf(" Terminal: %s, Current Net: %s\n" term~>name netName)
cond(
(netName == "vnn!"
printf(" Renaming net '%s' to 'vnn'\n" netName)
dbRenameNet(netObj "vnn")
(netName == "vpp!"
printf(" Renaming net '%s' to 'vpp'\n" netName)
dbRenameNet(netObj "vpp")
(t
printf(" Net '%s' is not vnn! or vpp!, skipping.\n" netName)
  • AR202509246930
    Thanks in advance!
    Code:
    netObj = term~>net
    cond(
    (netName == "vnn!"
    (netName == "vpp!"
    (t
    Andrew Beckett 11 months ago
    Please do not post the same question in different forums (the forum guidelines ask you not to do this). I joined your two posts together.
    The issue here is almost certainly that your instances a, b and c all have an instTerm connecting to the same net. If you find that net via just b or c, and rename it, it renames it everywhere - the net object is the same. The net is not a different object per instTerm.
    You would need to create a new net with the new name, and then update the instTerm connection to that new net rather than renaming the net itself.
