  3. Accessing SKILL runtime error locations outside the IDE...
  • Replies 8
  • Views 4882
Accessing SKILL runtime error locations outside the IDE (Vim workflow)
Trevor F
Trevor F 11 months ago
Good evening,
I primarily develop SKILL in Vim and rarely use the SKILL IDE. The IDE has one feature that I've been looking for ways to emulate. When a runtime error occurs, it focuses the editor on the offending line and highlights it.
Is there any way to access this same functionality through the public API outside of the IDE? I understand highlighting + viewpoint shifting definitely isn't possible, but  I could emulate this myself.
Anything would help, I could do highlighting if there was some way to at least get the line number.
I'm running version IC23.1-64b and follow the usual load("script.il") in the CIW and execute workflow.
Trevor Farias
    Andrew Beckett 11 months ago in reply to Trevor F +1
    Hi Trevor, Understood. In fact there was a recent discussion about setting line breakpoints outside of the IDE (see this post ); I recognise you are not asking about setting breakpoints, but the same…
  • Aurel B
    Aurel B 11 months ago in reply to Aurel B +1
    No idea why I could not format my code properly this time... The following defines an error handler that tries to look for the first errorful function in the stack and open its definition if you loaded…
  • Trevor F
    Trevor F 11 months ago in reply to Aurel B +1
    I was this close to sending a huge thank you, and then I saw the last comment... In all seriousness this is wonderful, I am 100% incorporating this masterpiece into my workflow. I very much appreciate…
    Trevor,
    There are APIs to cover much of the same functionality - you can put breakpoints on function entry and exit (breakpt()), you can trace functions (trace()), trace variables (tracev), you can continue (continue()), step() and next() and you can check info as to where you are: where(), dump(), stacktrace() etc. There's a manual that covers this...
    The one thing you can't do is set line breakpoints or find info on the line you're currently on (it reports the line it breaks at but not the line you are on after a step or next).
    However, given that it takes the same license to use the API to perform debug, why not use the IDE for this? I don't use the IDE for writing code, but I do use it for debugging - so I don't really see the point in "emulating" this...
  • Aurel B
    If you want to enter the dark side of SKILL, you can actually redefine the errorHandler function to whatever you like.
    Be careful
    Aurélien
  • Trevor F
    Trevor F 11 months ago in reply to Andrew Beckett
    I saw those functions and read the general error-handling docs but couldn't find anything that fit this quite niche case. I do actually use the IDE for debugging in most cases, but I wanted to perform less vim->IDE transitions thus wanted to see if I could find a generic errorHandler that didn't require me to do debugger functions like trace, or breakpoints.
    With the IDE I don't need to set breakpoints, it just magically finds the line throwing an error and positions towards it. I was just wondering if there was a way to grab this position, as to avoid having to avoid developing and debugging for minor issues on two windows. I apologize if my above post was unclear on that.
    Thanks for the response, I think Aurel B's below response probably is more what I'm looking for?
    Trevor
    Hi Trevor,
    Understood. In fact there was a recent discussion about setting line breakpoints outside of the IDE (see this post); I recognise you are not asking about setting breakpoints, but the same problem exists about retrieving line number information when the error occurs remains. I don't think defining your own errorHandler helps with that (this only works if you are not using the debugger, since that supersedes the error handler registered with ilAddTopLevelErrorHandler).
    I also use the IDE for debugging in this scenario when it stops at the line with the error - I just need to refresh the code in the IDE (and I stop it asking me each time to save the contents); yes it means I need to edit in vi/vim and refresh in the IDE, but the ability to see the line in the code, hover over variables (rather than typing them in the CIW) is still worth the (slight) pain...
    Now what I'd like is proper language server protocol support for SKILL and then you'd be able to use vim or neovim with an extension or VS Code, or Jetbrains etc etc. Sadly we've not done this yet...
  • Aurel B
    The following defines an error handler that tries to look for the first errorful function in the stack and open its definition if you loaded your files with debugMode enabled (and keepSrcInfo is probably required as well)
    (inScheme (let ()
    (defglobalfun errorHandler ( @rest errset_values
    @aux ( errport (symeval 'errport) ) ( stack_trace (get_stack_trace) )
    "Custom error handler to call editor on errorful file."
    ;; This function is minimalist on purpose as we don't want to raise errors inside the error handler
    (fprintf errport "%N\n" errset_values)
    (fprintf errport "%s\n" stack_trace)
    (errset (try_to_open_editor errset_values stack_trace) t)
    );fun
    (defun get_stack_trace ()
    "Return the current stack trace string."
    (let ( ( port (outstring) )
    (unwindProtect
    ;; 9999 is meant to be bigger than the maximum stack size
    ;; 8 is exactly the number of levels so that the stack trace do not report the functions we are currently defining
    ;; (When modifying this code, make sure to adapt this number accordingly)
    (progn (stacktrace t 9999 8 port) (getOutstring port))
    (close port)
    );unwind
    ));let ;fun
    (defun try_to_open_editor ( errset_values stack_trace )
    "Try to parse ERRSET_VALUES or STACK_TRACE to raise editor at the proper location."
    (let ( file line )
    (cond
    ;; Try to parse errset values
    ( (setq file (pcre_get_match "error while loading file - \"(.+)\"" (car (nth 4 errset_values))))
    (setq line (pcre_get_match "at line ([0-9]+)$" (car (nth 4 errset_values))))
    (open_editor file (if line (atoi line) 0))
    ;; Try to find the first function whose location is stored
    ;; Skip the first <<< Stack Trace >>> line
    ( (exists sexp_str (cdr (parseString stack_trace "\n"))
    (let ( ( sexp (linereadstring sexp_str))
    (when (and (listp sexp) (listp (car sexp)))
    (destructuringBind ( _file _line ) (get_function_source (caar sexp))
    (setq line _line)
    (setq file _file)
    ));dbind ;when
    ));let ;exists
    (open_editor file (cond ( (integerp line) line ) ( (stringp line) (atoi line) ) ( t 0 )))
    );cond
    ));let ;fun
    (defun get_function_source ( name "s" )
    "Try to get source information of function named NAME.
    This works only if function was loaded in debug mode and using `(sstatus keepSrcInfo t)`."
    (if (stringp (get name '_loadFile))
    ;; Function source is defined, use it
    (list (get name '_loadFile) (get name '_loadLine))
    ;; Try with `whereIs`, no idea if this is useful
    (letseq ( ( po_port (symeval 'poport) )
    ( tmp_port (outstring) )
    ( msg (unwindProtect
    (progn (set 'poport tmp_port) (funcall 'whereIs name) (getOutstring tmp_port))
    (progn (set 'poport po_port ) (close tmp_port))
    (list
    (pcre_get_match "is defined in file \"(.+)\"" msg)
    (pcre_get_match "at line ([0-9]+).$" msg)
    ));list ;letseq
    ));if ;defun
    (defun pcre_get_match ( pattern string "tt" )
    "Safely return the first PCRE group if PATTERN matches STRING, return nil otherwise"
    (let ( ( magic (rexMagic) )
    (unwindProtect
    (progn (rexMagic t) (when (pcreMatchp pattern string) (pcreSubstitute "\\1")))
    (rexMagic magic)
    ));let ;def
    (defun open_editor ( file line "tx" )
    "Open editor on FILE at LINE."
    ;; I do not despise `vi` users but I'm used to a better editor (which is also coded in Lisp!)
    ;; Feel free to replace it with whatever commands that will raise `vi` on the proper FILE+LINE
    (sh (lsprintf "emacsclient -n +%d '%s' &" line file))
    ));Scheme ;closure
  • RK56
    RK56 11 months ago
    Hi Trevor,
    May you find the answer you are seeking. I also use Vim more than Skill IDE. I'm curious to know your Vim setup/plugins to write skill scripts. Please share it in a separate post.
    Ram
  • Trevor F
    In all seriousness this is wonderful, I am 100% incorporating this masterpiece into my workflow. I very much appreciate this!
    Thanks, Trevor
  • Trevor F
    Trevor F 11 months ago in reply to RK56
    Hi Ram,
    I've made a whole host of functions to better facilitate my vim use; most notable is a IDE-linter equivalent that highlights + comments warnings/errors/hints on my vi window, and a lot of mechanisms to avoid repetitive tasks. I'll try and create a forums post tomorrow. As to my answer I seek, I believe Aurel has performed some magic, I'll be testing it tomorrow.
    Thanks, Trevor
