  3. Timing path sum is not correct?
  • Subscribers 95
  • Views 15316
eminemshow
eminemshow over 18 years ago
Hi, all:
Following is a report of optDesign
     optDesign Final Summary
|     Setup mode     |   all   | reg2reg | in2reg  | reg2out | in2out  | clkgate |
|           WNS (ns):| -0.131  | -0.131  | -0.061  | -0.103  |   N/A   |  0.012  |
|           TNS (ns):|-117.914 |-115.222 | -2.322  | -0.370  |   N/A   |  0.000  |
|    Violating Paths:|  2733   |  2673   |   55    |    5    |   N/A   |    0    |
|          All Paths:|  99908  |  99607  |  4544   |   174   |   N/A   |   889   |
Density: 60.258%
Routing Overflow: 0.00% H and 0.00% V
Real DRV (fanout, cap, tran): (0, 0, 0)
Total DRV (fanout, cap, tran): (0, 7, 0)
**optDesign ... cpu = 0:55:36, real = 0:55:41, mem = 2873.6M **
*** Finished optDesign ***
As we can see, the 'All Paths' line have several numbers, but 99607 + 4544 + 174 > 99908
why? (I didn't list clkgate group because it overlaps with reg2reg group)
Need someone to explain this.
BRs
  • dlferrao
    dlferrao over 18 years ago
     I just read an article about it on sourcelink:
    Results from timeDesign not matching between summary and individual timing reports
    Error Message:
    None
    Problem statement:
    After running timeDesign on a netlist using SOCE version 6.1, there are a set of reports
    generated including a summary report, and individual timing reports for the different path
    groups. These groups includ in2reg, reg2reg, reg2out, and clkgate.
    There are times when the WNS and number of violating paths reported in the
    summary report , don't match the values reported in the individual timing reports.
    Why are these results different?
    Solution:
    In this case, the problem was occurring when running post-CTS timing, and
    using the set_propagated_clocks [ all_clocks] constraint. In the original
    constraints there are several pin-level set_clock_latency constraints that were
    overriding the clock propagateion numbers, and caused a discrepency in the
    paths reported in the summary and the individual timing reports.
    Once the pin-level constraints were eliminated and the propagated clocks
    were allowed to be used for all of the checks, the WNS and total violating
    paths matched between the summary and the individual path fgroup timing reports.
