  3. Disable clock gating check for a module.
  • Subscribers 93
  • Views 18325
Tongju
Tongju over 18 years ago
For a FE_placed&routed block reported no timing violation, the sign-off tool (PT) catched several huge timing violations (>10ns) on paths  from top level input pins to dff "d" pins.
The issue traced back into a constraint "set_disable_clock_gating_check [get_cells {data_path/fifo/*}]". If I commented out this line from SDC file, then, FE saw those violations on in2reg pathes plus more pathes that are real clock gating path and should be disabled by the constraint.
I don't understand why the set_disable_clock_gating_check comand will disable pathes in the in2reg group. looks like PT is doing the right thing by not disabling them (the same SDC file, therefore, the same constrains have been used in PT).  Did anybody see the similar issue? How can I tell FE to only disable the real clock gating path for a sub-block? If I specify the individual stdcell pins like "a/b/c" in nand/nor gates after the set_disable_clock_gating_check, it works fine for me. But I try to avoid to expand the "data_path/fifo/*" all the way down into the individual nand/nor stdcell pins since there are quite few such kind of constraints coming from front-end group.
 Thank you for your advice!
Tongju
Tongju
