  3. replace library cells
  • Subscribers 94
  • Views 15296
designer
designer over 18 years ago
Hi all,
Do you know a command in RC which can replace a library cell in a verilog code with another library cell?
Masoud
  • grasshopper
    grasshopper over 18 years ago
     Hi designer,
    we usually use
    set_attr libcell [find / -libcell <cellName>] [find / -inst <inst_to_replace>]
    when the instance is pin compatible. If it is not pin compatible you probably have to resort to change_link and possibly some edit_netlist commands depending on what you are trying to do.
    good luck,
    gh-
  • designer
    Thank you grasshopper for the hint! The change_link command works fine!
    Masoud
