  3. Removing buffers
  • Subscribers 94
  • Views 15409
Removing buffers
designer
designer over 18 years ago
Hi All,
Does anybody know how we can avoid adding drc buffers between two modules? In the top-level there is a timing model of an analogue block (.lib file) and a digital block. The RTL Compiler adds buffers on paths between analogue and digital ports. The buffers are added to avoid drc violations. Is there a way to avoid generating these buffers?
Thank you in advance,
Masoud
  • Kari
    Kari over 18 years ago
     Hi Masoud,
    Did you try putting a set_dont_touch on those nets between the analog and digital blocks?
    - Kari
  • designer
    Thank you you for the email! I set the ideal_driver attribute of the pin to TRUE and it works now!
    Masoud
