  3. floorplan without initial core size
  • Subscribers 95
  • Views 15253
naderi
naderi over 18 years ago
 Hello all,
 I am wondering if it is possible to floorplan without specifying core size.
if the size of the chip be specified at the begining of the P&R, then a flow, to reach the minimum area, may be based on trial and error for diffrenet core sizes ( or core utilizations). Is this true? Can a tool like Encounter P&R with the minimum possible area?
Ali
  • Design4Life
    Design4Life over 18 years ago
    Hi Ali,
           If a core size isn't specified, usually a default number is used at the beginning, for example 70% utilization. Encounter also has beta functionality for an automated way of arriving at a minimal sized floorplan.
    regards,
    wt
  • naderi
     Thank you for your reply,
    Could you please explain a bit more the beta functionality and if there is any command associated?
    thanks
    Ali
