  3. SOCEncounter is not fixing hold violation
  • Subscribers 94
  • Views 19056
Sowjanya
Sowjanya over 18 years ago
I see very strange behaviour with SOC Encounter tool.  It is not fixing hold violations
eventhough there is a huge positive slack on setup for  several paths.
 Log files gives following message:
 No cell added.  (Degrade setup) (No Legal Location).
  "setOptMode -fixHoldSearchRadius <num>" may change this number. By default <num> = 40
 I am not able to find any description for "fixHoldSearchRadius" in encounter manual.
I experimented by giving a number of 500, but tool is taking the default number only.
 Did any of you guys face this problem?  What could it be ?
  • BobD
    BobD over 18 years ago
    When you examine the vicinity of the hold violation in the layout, do you see a landing area nearby that seems like it would accodomate a delay cell?
    Also, you might want to try re-running hold fixing with "setOptMode -verbose true" if you're not already.  The messaging might be more specific in that mode.
  • Sowjanya
     Yes, bob I do see a landing area nearby for placing a delay cell.
    The messages I sent were reported by turning on this option only "setOptMode -verbose true"
  • Kari
    Kari over 18 years ago
     Did you use cell padding on your flops to save this room for delay cells during hold fixing? If so, make sure you remove the cell padding (deleteAllCellPad) before trying to fix holds. Just a thought!
    - Kari
  • Sowjanya
     I'm not using any cellpadding for the flops.
    What I observe is the tool is trying to fix the hold looking at the start point only.At start point there is very little margin.
    Though it has lot of margin at the end point it is not trying to fix at the endpoint.
    I used  this option  "setOptMode -fixHoldAtSinkOnly true" also
  • Scrivner
    Scrivner over 18 years ago
    Another thing to try - if your design is very tight you may have exceeded the max utilization.
    Even if there is room available near the component with the violation, if you have exceeded
    the max utilization, it will not fix the violation.
     The default -maxDenisty setting is 0.95. Try setting it to 0.99. (setOptMode -maxDensity 0.99).
  • Kari
     At this point, I would use a script like the following:
    deleteAllCellPad
    setOptMode -noRPlace
    set endpoints { \
    "top/REG746/D" \
    "top/REG712/D" \
    foreach endpoint $endpoints {
      ecoAddRepeater -term $endpoint -relativeDistToSink 0.1 -cell BUFX2
    refinePlace -preserveRouting
     Then follow up with an ECO route and a new extraction and timing run.
    You can also script getting the endpoints with various options and the output of report_timing -machine_readable.
    Hope that helps,
    - Kari
