  3. Is this eco design flow right?
  • Replies 7
  • Subscribers 96
  • Views 18394
dota
dota over 18 years ago
In heirachical design, many iterations from top floorplan to block is need. If there are two version block patition data, such as:
1. old1.v (old netlist)  old1.def(old floorplan)  old2.v(after cts or fix timing) old2.def(after cts or fix timing)
2. new1.v(new netlist) new1.def(new floorplan)
 suppose (sram or mega cell) postion is fixed in old1.def & new1.def, It means floorplan has been done.
How to get new2.v & new2.def based on old2.v & old2.def, Is this eco design flow right or not below ?why?
1. load design of old1.v and old1.def
2. ecocomparenetlist -def new1.def -outfile old2new.eco
3. load design of old2.v and old2.def
4. loadECO old2new.eco
5. ecoPlace and ecoRoute to get new2.v & new2.def
  • Kari
    Kari over 18 years ago
     Hi Dota,
    Please look into the command ecoDesign. This may be what you're looking for.
    - Kari
  • dota
    Hi Kari
        thanks for your answer, But I think ecoDesign can't do the thing I want. ecoDesign refer two netlist, but what's I want refer three netlist (old1.v old2.v new1.v). Can you show a simple flow to help me resolve this problem.
    Dota
  • Kari
     Hi Dota,
    I guess I don't really understand what you're trying to do. Tell me if this is correct:
    • you start with a netlist/floorplan (start.v, start.def)
    • you do CTS and timing optimization on this netlist/floorplan (opt.v, opt.def)
    • changes have been made to the original netlist/floorplan (start_eco.v, start_eco.def)
    • you want to integrate those changes into the work you've already done in opt.v/opt.def
    If that is the case, then you would generally need to start over with start_eco.v and rerun CTS, optDesign, etc.
    - Kari
  • dota
    yes, you are right. I want to intergrate new netlist change into old netlist(after cts & opt) without run cts & opt again. any way can do it?
  • JZ Huo
    JZ Huo over 18 years ago
    Hi Dota,
         You can use Encounter Conformal ECO Flow.
    ECOs can also be classified as pre-mask or post-mask. For a pre-mask ECO, the software
    assumes any cell in the library is available for implementing the ECO. For a post-mask ECO,
    the software will restrict the implementation to only use spare cells.
    You can get more info from Encounter Conformal Equivalence Checking User Guide, but this feature
    requires a Conformal ECO license.
  • Sirrius
    Sirrius over 18 years ago
    Hi
     I want to learn ECOplace capability of Encounter. Specifically, I have a design, (and a netlist, a def etc)
    (a). I save the entire (original) design "SaveDesign... "
    (b). I now have a modified .v nelist.
    (c). From here on, I want to place the additional logic in the modified.v netlist into the original design (so I know the -fixPlaceInsts) option.
    The real queation is, how do I tell the tool to pick up a new .v file and process it? I am sure I am missing something major here.
    Can someone help?
    Devendra Rai
  • Scrivner
    Scrivner over 18 years ago
    You should use the ecoDesign command that Kari mentioned earlier in the thread. Below is the usage. Note that you specify the new netlist as one of the command arguments.
      ecoDesign [-postMask] [-modifyOnlyLayers MLb:MLt] {-spareCell spare} [-newSpareCellName suffix] [-useGACell GA_site] [-noEcoRoute] [-ecoSDC new.sdc] [-def fileName] [-fillerPrefix prefix] design.enc.dat top_cell new_netlist
