  3. Pin access violation
  • Subscribers 94
  • Views 20860
Ying
Ying over 18 years ago
When I run post-route optimization, a error "pin access violation" is reported, How can I do?
  • Kari
    Kari over 18 years ago
     Hi Ying,
    Does the message tell you which cell/pin is violating? Just offhand, it sounds like maybe you have some std cell pins stuck under a power bus or something like that.
    - Kari
  • Whiteman
    Whiteman over 7 years ago in reply to Kari
    Have the same problem. Is there any directive to place_opt_design avoid placement under power grid?
  • Dimo M
    Dimo M over 6 years ago in reply to Whiteman
    You can apply PG keep-outs on the pins of base cells using the specify_pg_keepout command. You can find further details and an example here: support.cadence.com/.../ArticleAttachmentPortal
