  3. how to use create_op_cond problem
  • Subscribers 94
  • Views 15167
dota
dota over 18 years ago
In encounter, create_op_cond -name worst -library_file worst.lib -P 1 -V 1.5 -T 0 is a simple command example .
If there are more than two libs (such as worst1.lib ,worst2.lib), How do I use create_op_cond  to build a virutal operation? Or only one library_file(worst1.lib) is enough ?
Dota
  • Ramakrishna
    Ramakrishna over 18 years ago
    You don't need to create in every library. You need to specify one per delay_corner. Any library defined in the library_set of that delay_corner can be used. There are op_conds already each of the libraries. You need to define only if none of the op_conds defined in the library don't satisfy your PVT requirements.
