  3. ETS and FE
  • Subscribers 94
  • Views 14825
ETS and FE
asicpro
asicpro over 18 years ago
has anybody seen any differences in ETS and FE noise reports.  Most of the time i get more glitch or delay violations inside ETS although FE is clean.   Has anyone tried to fix the additional viols reported by ETS. if so how...
  • Kari
    Kari over 18 years ago
     I ran noise analysis in ETS just yesterday and compared to my FE noise run, and the results were identical. I would double-check the setup used in both tools to make sure they match. In FE, use getSIMode, and in ETS look for anything in your script using set_noise_run_mode, set_noise_parm, set_virtual_attacker, set_noise_thresh, etc.
    - Kari
