  3. sdf backannotation
  • Subscribers 95
  • Views 16200
sdf backannotation
gops
gops over 18 years ago
I have generated the netlist(verilog) and sdf file from Encounter.Now i need to simulate the netlist in nclaunch.Can any one please tell what are the library files required for the purpose. I have vital libraries with me , but they are of .vhd extension. Can i use those vital libraris for simulating verilog netlist OR do i need to procure any verilog libraries for the same?
  • Mickey
    Mickey over 18 years ago
    Although you can use the vhdl library, it would be best to obtain and use a verilog version of the library cells. This is because there could be a large performance impact due to having to transition through the language boundary for every cell.  The library would be something provided by the vendor whose cells are being used.
    Since you already have VHDL libraries, another method could be to have the netlist created in VHDL.
    Let me know if this helps.
    Best regards,
    Mickey
  • gops
    Hi Mickey;
    thanks for the reply.
    You told to create the netlist in VHDL.
    But i think its not possible to generate VHDL netlist from encounter.Isn't it ?
    thanks
    gops
  • Mickey
    Hi Gops,
    Unfortunately I missed the indication that you are using Encounter.  With that in mind it would be good to use a verilog version of the cell library.  You can still use the VHDL library if you don't have a verilog version, but there will more than likely be a performance impact due to the large number of language boundary crossings that can be forseen in such a situation.
    Best regards,
    Mickey
  • gops
    Hi Mickey;
    gops.
