  3. GDS II streaming out.
  • Subscribers 95
  • Views 16506
gops
gops over 18 years ago
I need to stream out GDS file from encounter.Then should i need to merge the gds files of all the standard cells that i used in my design?.Also i need to do the LVS .How should i do the LVS .I think cdl is needed to do LVS .so somebody please give me the guidance to stream out GDS II and do the LVS?
  • themperek
    themperek over 18 years ago
    Ehen it goes to Virtuoso : http://www.vtvt.ece.vt.edu/vlsidesign/tutorialCadence_importGDS.php
     For LVS you can import verilog netlist and do LVS.
    TH
  • Kari
    Kari over 18 years ago
    There are a couple of ways you can merge in your full layouts:
    - use the following switch in your FE streamOut command: -merge {listOfExternalGDSFiles}
    - stream the FE GDS into a DFII library that contains all of your std cells, rams, IOs, etc.
    As for LVS, the flow can be different depending on the designer and the tool used. A general flow would be to output a physical netlist from FE, which the LVS tool may or may not convert to a spice netlist, and then run LVS pointing to the full GDS of your design and this physical netlist.
    - Kari
  • gops
    Hi Kari; Thanks for the reply.
