  3. ecoDeleteRepeater command bug in encounter
  • Subscribers 94
  • Views 16003
dota
dota over 18 years ago
   I try to delete inverter between feedthrough port by ecoDeleteRepeater command. But unfortunately, there are only a pair of inverter between input and output.  As we all know, encounter can't allow input port connect to output port directly. So ecoDeleteRepeater leave ERROR message below:
encounter 2> ecoDeleteRepeater -inst U1240_ICCOPT
Using detail cap. scale factor for clock nets.
Width-based sheet resistance table (silicon width) is used ...
**ERROR: (SOCECO-491):  The buffer U1240_ICCOPT has both input and output ports connected to external nets.
Delete U1240_ICCOPT (SC32INVXH1).
Delete U1241_ICCOPT (SC32INVXQ1).
Then I check this feed through and find , only one inverter is deleted and the other is still in netlist. So at this case, ecoDeleteRepeater change the logical connection in netlist, I think it's dangerous and need to fix.
Dota
  • Kari
    Kari over 17 years ago
     Hi Dota,
     Please file a CCR on this.
    - Kari
  • dota
    dota over 17 years ago
    Hi, Kari
            thanks for reply. I don't know how to file CCR. And It's said that only cadence internal person have permission to do this.
    Dota
  • Kari
     Dota,
     You can open a service request through SourceLink.
     - Kari
