  3. dummy lefs
  • Subscribers 92
  • Views 13765
dummy lefs
spach
spach over 16 years ago
how can i get dummy lefs for macros to proceed with pnr?
regards
suresh
  • Kari
    Kari over 16 years ago
     Suresh,
    I just posted to your other LEF thread, so you could try the ways I mentioned there - but if you just need something quick, you can create one by hand. Use another LEF that has MACRO definitions as a template, and enter the size of your macro. Pins can be more difficult - sometimes you can write a quick perl script or something to output pin info in LEF format. If your MACRO only has a few pins, you can do it by hand, but I'm guessing your macro has more than a few. Don't forget to add blockages. The macro vendor should have included a LEF, but if you are creating the macro yourself, you should probably look into either exporting LEF from Virtuoso, or using an abstract tool.
    - Kari
