  3. Routing 2 cells together
  • Subscribers 94
  • Views 14483
Mooty
Mooty over 17 years ago
What is the command used to route 2 cells as closely as together as in the case of clock gating ?
mooty
  • BobD
    BobD over 17 years ago
    Hi Mooty, I'm not sure if you're wanting the clock gating cells *placed* nearby downstream register -or- some way to influence routing behavior, but if you're seeking to instruct the placer to place clock gating cells at the center of gravity of the registers they drive you might want to try "setPlaceMode -clkGateAware true". Feel free to follow-up if this isn't what you're looking to achieve. Hope this helps, Bob
