  3. Using the Forum
  • Subscribers 93
  • Views 14969
Using the Forum
archive over 20 years ago
Welcome to the digital IC Place and Route forum; a place to keep your finger on the pulse of the latest software developments and happenings in the areas you care about most. Get to know the experts, both inside Cadence and in our worldwide Encounter user community. Ask your questions, get answers, and share best practices. Tell us what's on your mind...other users want to know what you think.
This forum is not intended to be a substitute for Cadence customer support and/or documentation, but we do believe that it will be helpful and a way to tap into vast knowledge that exists in our user community. Of course, any software support, documentation and installation issues should also be directed to your preferred Cadence support channels.
File attachments must use one of the following file extensions:.doc, .pdf, .html .zip, .il,.jpg,and .gif. Size limit on the attachments is 750KB. If you have questions or need help with attachments, send an email to community_moderator@cndusers.org
Accounts of registered members of the former Encounter community have been moved over to this new community so no need to re-register. Questions and comments about the site can be posted on the general forum, Suggestions.
Originally posted in cdnusers.org by Moderator
    I've got every time a difference result when I ran placedesign (related to congestion) after I've changed some power grid even though the same placementguides have been used.
    My question is how can I specify the startpoint  (sheetfactor ??? ) so that the placedesign should start at the same point.
    Thanks.
    Originally posted in cdnusers.org by DN
