  3. Decap cells
  • Replies 12
  • Subscribers 98
  • Views 34348
Decap cells
gops
gops over 17 years ago
Can any body please tell me in detail how decap cells helps in reducing IR drop .
  • moh sadeghi
    moh sadeghi over 17 years ago +1
    Hi Gopakumar Decap cells are typically poly gate transistors where source and drain are connected to the ground rail, and the gate is connected to the power rail. As already mentioned on the forum, when…
  • vs8747
    vs8747 over 7 years ago in reply to moh sadeghi
    Hi Mohammad
    Nicely explained but my query is that
    Is it preferable to connect directly power  to gate terminal ?
    and could you please elaborate on how decaps have more leakage?
    vs8747
  • HTRIVEDI
    HTRIVEDI over 7 years ago in reply to vs8747
    This is a very important question. Gate oxide directly to supply is an ERC violation. Is this waived in the digital environment, or is there any series protection with the gate of the decap to protect it under ESD. The lower the voltage, the thinner the gate oxide, so even though the gate oxide rupture potential could be higher than supply spec. there is still a risk. Does anyone have a pointer to a useful layout design that protects the decap under ESD? Or is it purely gate to supply rail.
