  3. well tap and End cap cells
  • Subscribers 96
  • Views 26667
gops
gops over 17 years ago
What are well tap , end cap and spare cells? What is their purpose. ( I have read that well tap cells are used to limit resistance between power or ground connections to wells of the substrate, What is the advantage in reducing this resistance). Are Well tap and End cap cells technology dependent OR are they a must in every design. How could I fix the maximum number of well tap cells in a design?
  • jkang
    jkang over 17 years ago +1
    Well taps are traditionally used so that your VDD and GND are connected to subtrate and n-wells respectively. This is to help tie them to your VDD and GND levels so that they don't drift too much (especially…
  • Kari
    Kari over 17 years ago
     The rules for welltaps and endcaps are very technology dependent. Some technologies don't require them at all (or, the taps are built in to the std cells), and for other technologies you may need a welltap every X microns, and endcaps at the end of every std cell row. The DRC deck should flag any issues regarding welltaps/endcaps, which is one good reason to run an early DRC. You will have to consult the design rule manual for your process.
     Spare cells are not required, but are usually a good idea. If you want to go back later and do a small functional ECO to your design, you can use the spare cells which are already placed around the design, and connect them with minimal mask changes (also called a metal-only ECO).
  • jkang
    Well taps are traditionally used so that your VDD and GND are connected to subtrate and n-wells respectively. This is to help tie them to your VDD and GND levels so that they don't drift too much (especially towards the middle of the chip) and cause latchup.
