  3. Set cell dont use
  • Subscribers 93
  • Views 20002
Set cell dont use
archive over 20 years ago
I'm trying to forbid some cells to use in Encounter during optimize
just like below:
dbSetIsCellDontUse [dbGetCellByName bfx05pdv] 1
dbSetIsCellDontUse [dbGetCellByName ivx05pdv] 1
But during the optimisatiom FE did still use these cells.
Also when I looked at the dontusecells list, these cells are
defined inside.
Do you have any suggestions?
Originally posted in cdnusers.org by DN
    add the following to your sdc file should do it.
    set_dont_use "bfx05pdv ivx05pdv" TRUE
    li siang
    Originally posted in cdnusers.org by lisiang
    After using db command, you must use "setupfootprint" to update the cell's footprint usage prior to using optDesign.
    BTW, some commands may refresh the dontuse setting on your internal command setting. So it is safe to use sdc. If you insist on using db command, you can use it immediately before optimization command.
    Originally posted in cdnusers.org by yasonwang
    The reply is late, but maybe useful for reference.
    It is common to load both min and max library into Encounter. A side effect in this is that when setting "setDontUse", you have to set it for both libraries! Do something like
    setDontUse someLibbc/DELAY1 true
    setDontUse someLibwc/DELAY1 true
    Eng Han
    Originally posted in cdnusers.org by EngHan
