  3. metals for routing
  • Subscribers 94
  • Views 15963
metals for routing
gops
gops over 17 years ago
For an 8 layer metal process, what are the metal layers usually used for 1)power rings. 2)power stripes 3)clock routing.
  • Kari
    Kari over 17 years ago
     I mentioned some of this in a reply to your other post about power stripes, but again it really depends on the design. For a recent 8-layer design, we had std cell rails on m1, stripes on metals 4 - 8. I don't recall what layers we did rings in. Make it easy for connecting to IO cells. As for clock routing, since clocks are usually routed before everything else, they tend to end up on layers 3 - 5. You can specify preferred top and bottom layers in the .ctstch file. You may want to limit the top layer, for example, if you have thicker metal on your upper layers and you don't want to use them for the clocks.
