  3. Excluded pin during CTS
  • Subscribers 93
  • Views 17996
archive over 20 years ago
During CTS-run I've defined my clocktree as below:
AutoCTSRootPin TIMMCORE/u_core/u_coss/u_efc/u_fb_fs/f_wre_reg/Q
MaxDelay 7.0ns # set_clock_latency
MinDelay 6.7ns # default value
MaxSkew 300ps # set_clock_uncertainty
SinkMaxTran 900ps # set_clock_transition
BufMaxTran 900ps # set_clock_transition
Buffer dly1x3pdv dly2x3pdv dly2x8pdv dly3x3pdv
RouteType standard_clk
AddDriverCell cnbfx6pdv
PadBufAfterGate NO
NoGating NO
DetailReport YES
RouteClkNet YES
PostOpt YES
ExcludedPin
+ TIMMCORE/u_core/u_coss/u_efc/u_fb_fs/loc_tdo7_reg/TI
LeafPin
+ TIMMCORE/u_core/u_coss/u_efc/u_flash/WRE
END
But after CTS, the delay from the clock root to */TI
as same as the delay to the */WRE. My expecting is that the */TI pin should be excluded from the clocktree.
Ps. I'm using (cadence_fe 04.20-s315_1_USR2 )
Originally posted in cdnusers.org by DN
    I've just found that when you define (SetDPinAsSync YES) in the CTS-configuration file then it works.
    From user guider
    SetDPinAsSync YES | NO
    Controls whether CTS automatically treats the D-pins of flip-flops as synchronous pins.
    D-pins include
    Data pins
    Enable pins
    Scan-in pins
    Scan-enable pins
    Synchronous set and reset pins
    Default: If you omit this statement, CTS treats the D-pins of flip-flops as excluded pins. That is, CTS does not treat the pins as synchronous pins.
    Hi, Let me add few more comments on your topics,
    The alternative way other then adding in script file is by setting the same in CTSMode "setCTSMode -setDPinAsSync " before loading ctstch script file.
    Then this is global for all the other CTS trees.
    Its allways adviceble to set soft rule for Preferred layers like avalable top metals (M5 , M4 ) in setCTSMode command .
    like ( setCTSMode -topPreferredLayer M4  -bottomPreferredLayer M3 ) .
    BTW how was your correlation of skew and delay between clk- route only and post route phase.
    Mohan
    Originally posted in cdnusers.org by mohanch007
    Mohan
