  3. TCL expr inside curly braces
  • Subscribers 94
  • Views 16434
jkang
jkang over 17 years ago
I'm trying to run a repairPowerWire inside a specified area but I want to code up my script to be easily modified. So I've created variables for the location and size of various blocks and I want to run repairPowerWire on specified areas only.
The problem is, the -area option has to be followed by four coordinates in curly braces, e.g.:
repairPowerWire -area {0 0 10 10}
Well, the area I want to specify are contained in variables. Furthermore, I would like to calculate the top corner coordinates using an expr {}.
Since the {} braces are considered grouping in TCL, this effectively prevents me from putting expressions inside the -area option. Does anyone know a way to get around this?
  • BobD
    BobD over 17 years ago
    Hi jkang,
    The curly braces are implying that the command is expecting a list containing 4 elements rather than flat space-separate values.
    Try passing the coordinates like this:
    repairPowerWire -area [list $llx $lly $urx $ury]
    Hope this helps,
    Bob
