  3. Nanoroute crashes
  • Subscribers 94
  • Views 15918
Nanoroute crashes
mastrojohn
mastrojohn over 17 years ago
I am a student of Technical University of Crete trying to finish a project. My goal is to make a simple chip implementing an algorithm. For this purpose I used RTL Compiler to synthesize my VHDL code and then I used SOCE 6.2 with updates for place and route. The target technology is a Faraday/UMC 90nm standard performace process. Everything seems to be fine until I try to have Nanoroute route my design. It is a small design of approximately 94000 std cell instances. When I route the core alone without adding pads, everything is ok. But when I load the netlist with the pads and try the global detail routing with nanoroute i get this message:
 #WARNING (NRIG-39)  Pin clk doesn't have physical shapes !
#WARNING (NRIG-39)  Pin reset doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[31] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[30] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[29] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[28] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[27] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[26] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[25] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[24] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[23] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[22] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[21] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[20] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[19] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[18] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[17] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[16] doesn't have physical shapes !
#WARNING (NRIG-39)  Pin input[15] doesn't have physical shapes !
#WARNING (NRIG-39 Repeated 20 times. Will be suppressed.)  Pin input[14] doesn't have physical shapes !
#Start reading timing information from file .timing_file.tif ...
#The worst setup slack read in is -3.446
#No hold time constraints read in
#Read in timing information for 105 ports, 94412 instances.
#NanoRoute Version v06.20-s090 NR070717-1629/USR50-UB
#Checked out 1 Multithread_Route_Option license.
#LM Super/Multi-Thread mode: LM use 2 threads
#Using S.M.A.R.T. routing technology.
#Start data preparation...
#WARNING (NREX-28) The height of the first routing layer metal1 is 0.000000. It should be larger than 0.000000
#WARNING (NREX-30) Please also check the height and metal thickness values for the routing layers heigher than routing layer metal1
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace in log file.
Hangup
Does anyone know what could be the cause of this??
I load first the three lefs of core cells (header+macro+ant) with this order, then a memory lef and finally three IO lefs(header+macro+ant).
Thanks in advance!
  • Kari
    Kari over 17 years ago
     When you say "header" lef, do you mean the technology lef? The one that defines the metal and via layers, spacings, widths, etc.? If so, you should only read one of those in and it needs to be the very first lef you read in. It sounds like you are reading one in with the std cells, then another with the IOs. I'm not sure if that's the problem, but it's the first thing I would look into.
  • mastrojohn
    Dear Kari,
     Actually yes, the header lef is the technology lef and I load two of them. I will try to read one and hope that this will resolve the situation. Thanks for your attention!
