  3. Finding pin locations
  • Subscribers 93
  • Views 17076
archive over 20 years ago
Hi, I use this to find an instance location: set instPtr [dbGetInstByName $instName] set loc [dbInstBox $instPtr] set llx [dbDBUToMicrons [lindex $loc 0]] set lly [dbDBUToMicrons [lindex $loc 1]] set urx [dbDBUToMicrons [lindex $loc 2]] set ury [dbDBUToMicrons [lindex $loc 3]] But, How do I find a pin location? Thanks Chris
Originally posted in cdnusers.org by ChrisS
    Hi Chris,
    You can use:
    dbForEachCellFterm
    To go through each cell pin.
    You can then pass each ftermPtr from dbForEachCellFterm to:
    dbFtermLoc
    To get the pin location.
    set pinLoc [dbFtermLoc $ftermPtr]
    Then lindex into pinLoc:
    set x_loc [lindex $pinLoc 0]
    set y_loc [lindex $pinLoc 1]
    You'll also want to convert from db units to microns like you did in your cell example.
    Good luck!
    Elvis
    Originally posted in cdnusers.org by elvis
    you can use the following tcl procedure to zoom into a instance pin
    usage: z2ip some_hier/some_instance/some_pin
    proc z2ip { instName {pinName ""} } {
            if { $pinName == "" } {
                    set pinName [file tail $instName]
                    set instName [file dirname $instName]
            } else {
                    set instName $instName
            set termPtr [dbGetTermByName $instPtr $pinName]
            set termInst [dbTermInst $termPtr]
            set termName [dbTermName $termPtr]
            set termInstName [dbTermInstName $termPtr]
            set termLoc [dbTermLoc $termPtr]
            set termBox [dbTermBox $termPtr]
            set termBox0 [expr [lindex $termBox 0] *[dbHeadMicronPerDBU] ]
            set termBox1 [expr [lindex $termBox 1] *[dbHeadMicronPerDBU] ]
            set termBox2 [expr [lindex $termBox 2] *[dbHeadMicronPerDBU] ]
            set termBox3 [expr [lindex $termBox 3] *[dbHeadMicronPerDBU] ]
            set termBox [list $termBox0 $termBox1 $termBox2 $termBox3]
            set termWidth [expr $termBox2 - $termBox0]
            set termHeight [expr $termBox3 - $termBox1]
            set termLayer [dbTermLayer $termPtr]
            set termLoc_X [expr [lindex $termLoc 0] *[dbHeadMicronPerDBU] ]
            set termLoc_Y [expr [lindex $termLoc 1] *[dbHeadMicronPerDBU] ]
            set x0 [expr $termLoc_X - 1]
            set y0 [expr $termLoc_Y - 1]
            set x1 [expr $x0 + 2]
            set y1 [expr $y0 + 2]
            zoomBox $x0 $y0 $x1 $y1
            set netPtr [dbTermNet $termPtr]
            puts "$instName pinLoc: $termLoc_X $termLoc_Y ; width: $termWidth height: $termHeight "
    li siang
    Originally posted in cdnusers.org by lisiang
