  3. non R0 partition
  • Subscribers 94
  • Views 14538
non R0 partition
asicpro
asicpro over 17 years ago
I have a smaller block which is used as a partition in a higher level module. I tried to change the orientation  of the lower level partition and FE allows me to do that. However if i flatten the database after the block level is fully routed at the top level i do not see the lower level cells correctly oriented ( their oriented is still the default ).  is there a cadence document that addresses this issue... thanks a lot-
pjay
  • Kari
    Kari over 17 years ago
     Hi Pjay,
    Can you explain how you changed the orientation of the partition, and also how you flatten the design later? What you are trying to do should work, it sounds like something is just out of sync - the orientation of the partition in the top-level floorplan file, for example.
    - Kari
