  3. QRC tch file
  • Subscribers 94
  • Views 25414
QRC tch file
diablo
diablo over 17 years ago
 There are 3 QRC techfile , typ, bst and wst. Is there a way to read all these 3 QRC techfile using set rda_Input(ui_qxtech_file) and use them as suitable in different analysis view?
For example, while doing MMMC analysis, can we do something like this
 set_analysis_view -setup wosrt -hold best
extractRC using whichever QRC tch file is appropriate (not sure how to tell the tool which QRC tch file to use)
then timeDesign to get report
  • Kari
    Kari over 17 years ago
    If you're doing MMMC, then your analysis views were set up with the create_analysis_view command which included a -delay_corner option. The delay corners are setup up with the create_delay_corner command which has a -rc_corner option. Finally, the create_rc_corner command is what points to the QRC tech files:
    create_rc_corner -name worst \
                    -cap_table "worst.CapTbl" \
                    -T 125 \
                    -qx_tech_file "worst.tch"
    Having said that, extractRC is the built-in FE extraction which uses cap tables. If you want to use QRC for extraction, you'll need to use runQRC. QRC will then be run for all corners referenced by your active views.
    So, just make sure you've got everything set up correctly in your MMMC commands, and you're good to go! (When using MMMC, it's the data in the MMMC commands that matters, not what's in the .conf file.)
    - Kari
  • diablo
     Thanks Kari. That was really helpful. Just wondering If i am doing timeDesign -signoff, do i still need to to runQRC before doing timeDesign or does the switch -signoff tells the tool to call runQRC iteratively to generate and annotate SPEF files for RC corners.
  • Kari
     You're welcome, I'm glad it helped!
    Using the -signoff switch with timeDesign will automatically run QRC for all your active views, so you don't have to do it separately beforehand.  If you want detailed reports for each view (meaning, a separate directory for each view with all the reports for that view), make sure to use -expandedViews.
    - Kari
