  3. Is there a way to load a previously-saved verifyGeom report...
  • Subscribers 95
  • Views 15075
Is there a way to load a previously-saved verifyGeom report?
jgentry
jgentry over 17 years ago
I noticed that my last verifyGeom run saved a <block>.geom.rpt file.  However, when I go to load the violations, I don't get an option to load violations from SoCE (only Assura, Calibre, etc.).  Anybody know how to load this in?  Note that I am loading from DEF and NOT a saved SoCE design.
  • dlferrao
    dlferrao over 17 years ago
    What you can do is:
    After verifyGeometry run, you can savethe DRC markers using:
    saveDrc filename.drc
    Then you can later load this file using:
    loadDrc filename.drc
    I don't know why loadViolationReport do not support SOCE own format.
  • jgentry
     I'll add that to my verifyGeom scripts so that I don't waste time re-running verifyGeom multiple times just to get the same answer.
    JG
