  3. How to increase timing table dimensions in a lib file created...
  • Subscribers 94
  • Views 14865
How to increase timing table dimensions in a lib file created from do_extract_model
vavendan
vavendan over 17 years ago
Hi
I generated a lib file with the command do_extract_model but the timing table dimension have only 2 dimensions. I need to increase the timing table in all range of the input slew clock, I mean , I need to generate timing tables with dimension 5x5. I used the switches -input_slews {input_slew1 input_slew2 ... input_slew5}, -clock_slews {clock_slew1 clock_slew2 ... clock_slew5 and output loads {load1 load2 ... load5}
But the timing tables keep the same dimension.
Please Could you help to solve this issue?
  • Kari
    Kari over 17 years ago
    What version of the tool are you using? It looks like this was an issue fixed in 7.1 USR3 and 8.1.
    - Kari
