  3. How to remove empty module after optDesign?
  • Subscribers 92
  • Views 15452
archive over 19 years ago
After mijn optDesign run in PostCts-stage I've got following messages:
Found empty module (abl_frss_SHELL_BUF_SPC_65).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_88).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_120).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_121).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_122).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_123).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_124).
Found empty module (abl_ivnss_6c_8l_SHELL_BUF_SPC_125).
Found empty module (glrd_pinmux_TCB_SHADOW_FF_SPC_16).
Found empty module (glrd_pinmux_TCB_SHADOW_FF_SPC_17).
Found empty module (glrd_pinmux_TCB_SHADOW_FF_SPC_18).
How can I remove these cells (which are generated by FE) after optimize? Because I've
got some mismatchs for my LVS-run and I dont want to modified my netlist.
Thanks and Regards,
Originally posted in cdnusers.org by DN
    Hi , can you let us know if this is a warning or ERROR message on encounter ,
    BTW did you sow such messages during LVS run like V2LVS ??
    Originally posted in cdnusers.org by mohanch007
    This is a message (No error or warning) from First Encounter (v04.20-s315_1) when I restore the design back from database.
    From LVS I've got a mismatch because of the empty modules in cdl netlist so when I'm removing these from cdl then the LVS result is OK.
  • Kevin P Thomas
    Kevin P Thomas over 14 years ago
     deleteEmptyModule command will delete all the enpty modules
