  3. Power pads estimation
  • Subscribers 93
  • Views 15106
archive over 20 years ago
Hi all,
I'm using SoC Encounter to
obtain a statistical power estimation of my chip.
I've set different external loads
on the io pads by mean  of several sdc
constraint files.
The problem is that the power consumption of
the pads doesn't change at all for different
 external loads.
I'm using the "dummy_clock"  option.
Can anybody help me?
Thank you
Originally posted in cdnusers.org by giohdl
    I'm sorry...
    The problem was just the syntax
    of the  SDC  command to set pad loads.
    I've found the solution in the PowerMeter Manual.
    Thank you.
