  3. design import using OpenAccess
  • Subscribers 94
  • Views 15152
diablo
diablo over 17 years ago
 I have a verilog netlist out of RTL compiler and Open Access physical libraries for standard cells. How to import a design into encounter using verilog netlist and Open Access physical libraries? When using Design->Import Design -> Advanced -> OpenAccess there is option of OA netlist. Is it possible to import the design using verilog netlist?
  • eklikeroomys
    eklikeroomys over 15 years ago
    Yes you can, you just leave the import openaccess netlist option unselected, and import your verilog netlist the normal way
