  3. IO file and variables
  • Replies 7
  • Subscribers 94
  • Views 18512
mcdjnaja
mcdjnaja over 17 years ago
I'm just arriving in this forum and would thank you for all good answers to my questions.
I would like to know if the IO file is the only file for the design flow of SOC Encounter in which we can't use variables ? In my case, i place the IO pins manually and after automatically with use of variables, depending on generic design values.
 Thanks in advance.
  • Kari
    Kari over 17 years ago
     Could you give an example of what you're trying to do?
  • mcdjnaja
     An example is different tests of placement with different sizes (due to the shape of the design), so the pins are not placed at the same position. This design is hierarchical, so i must have the pins at the same position on the Y axis, thus depending on the design size (described with variables).
  • Kari
     There are two different formats of the IO file - location based (exact coordinates) and sequence based (with offset and spacings). Have you looked at the sequence-based format? I'm not sure it's exactly what you want, but it may be close.
  • mcdjnaja
     Yes, exact, it is what i use. But the problem is about offset and spacing values. Thus, i use a script to generate an io file with variables in the script for offset and spacing values.
    Thanks in advance for your quick answers !
  • Kari
     Sounds like you're already doing it the most efficient way then. Maybe some experts out there will have another idea...
  • mcdjnaja
     I hope some experts will be interested in my way to correct this problem !! (for a complete configurable flow)
    Anyway, thanks for your help Kari !
  • Kari
     You could always file an enhancement request through Sourcelink.
