  3. What is OPC based metal fill ?
  • Subscribers 94
  • Views 18220
NAADHAN
NAADHAN over 17 years ago
Hi All ,
              Pls explain what is OPC based metal fill.??
Thanks & Regards,
NAADHAN
  • NAADHAN
    Hi ,
    I got some idea on what is meant by OPC metal fill.
    OPC ----> Optical Proximity Correction
    In OPC MetalFill --->the dimensions of each MetalFill is biggerthan normal MetalFill & indeed it doesnt need further OPC correction.
    In Normal Metal fill ----> fill dimensions are comparable to the smallest geometry possible(for the tool) & this needs OPC correction.
    Why we need OPC ?? ---> When the dimensions of the layout are very small, while mask preparations diffraction occurs at the edges/corners which results in rounding of the corners of the mask pattern. So we need a OPC correction for normal metafill.
    This is what i was able to get.... any corrections on this and additional information on this is welcomed...
    Thanks & Regards,
    NAADHAN
