  3. reporting RC values of particular signal nets
  • Subscribers 95
  • Views 15538
spach
spach over 17 years ago
can any one tell me the encounter commands to find the RC values for the selected signal nets in a completely routed design.
 regards
spach
    archive over 17 years ago
    Hi Spach, you can use the following script to report the same proc userSelectedNetsRCDump { rpt } { set f [ open $rpt w ] dbForEachCellNet [dbgTopCell] netPtr { if { $netPtr != 0x0 } { if { [dbIsNetSel $netPtr]} { set name [ dbNetName $netPtr ] set rc [dbNetExtrRCSummary $netPtr ] set totalNetRes [lindex $rc end] set totalNetCap [ lindex $rc 1] puts $f " $name : $totalNetRes ohm $totalNetCap pf " } } } close $f } *********** you need to run report_timing before you use this script. Hope this helps. +Vishnu
  • NAADHAN
    NAADHAN over 17 years ago
    Hi ,
                      Thanks Vishnu.....Thanks Spach..... will try this let you know :-)
