  3. Operating Conditions during predict_qos and synthesize ...
  • Subscribers 94
  • Views 1327
Operating Conditions during predict_qos and synthesize -to_placed process.
admin
admin over 17 years ago
Hi there,
How can I change the operating conditions to ensure that RC extraction agrees with my synthesis settings?
Is the RTL Compiler physical synthesis enough, or the best practice is to run trial place and route on the Encounter?
At least in Encounter I have more control over the RC extraction process.
  • grasshopper
    grasshopper over 17 years ago
    Hi Julian,
     not sure I follow your question but operating conditions used in RTL Compiler are honored during R/C extraction so both should line up when using RTL Compiler Physical. In addition operating conitions changes using something like
    set_attr temperature 43.2 [find / -operating_condition nominal]
     will also be taken into account during R/C extraction
     hope this helps,
    gh-
  • admin
    Hi, thanks for reply.
     What happens with my design is that when executing the predict_qos method the tool recognizes my settings, however, when the encounter starts the spef wrote process, the system puts the follow message:
     rcOut Option :  -spef ../deliverables/logic/my_design.spef
    RC Out has the following PVT Info:
       RC-typical , Operating temperature 25 C
    Dumping Spef file.....
    ***** SPEF Out Finished (CPU Time: 0:00:00.1  MEM: 222.766M)
    and the Operating condition temperature is not the original one anymore
     I will try to run the same process with another library and conditions to check.
    Another issue that I observe is that the predict_qos does not maintain the DRV and exceeds the max transition and max capacitance limits, even when using the follow commands.
    set_attribute drc_first true
    set_attribute drc_max_trans_first true
  • grasshopper
     Hi Julian,
     just curious what version you are using; predict_qos as a use model was deprecated a few versions back in favor of
     > synthesize -to_placed . . .
     Can you try a later version and report back
     thanks,
    gh-
