  3. command description needed
  • Subscribers 94
  • Views 15282
svcadence
svcadence over 17 years ago
Can anyone explain me about the following commands in SOC encounter
unlogcommand selectinst
sv
  • BobD
    BobD over 17 years ago
    They're non-productized commands (meaning you're free to use them but they're not officially supported) that give you a way to influence which commands are logged (in your .cmd file and in your .log file with the <cmd> notation).
    One situation where they can be useful is if you're written a custom proc and you want that to appear in the log file with a <cmd> notation and in your .cmd file, you can use the logCommand command to achieve this behavior.
    Another is if you've found that a certain command is being logged thousands of times and you want to suppress that logging.
    Note that this doesn't influence whether the output of the commands is logged- just whether the command itself is logged.
    Let me know if that doesn't explain it.
    Bob
  • svcadence
    Thank you Bob,
    Iam clear with your explanation..
    sv
