  3. Tcl Scripting encounter
  • Subscribers 93
  • Views 17402
archive over 20 years ago
Hi all,
I'm developing custom tcl scripts in Encounter for block floorplanning.
I can't execute the addStripe command with variables as "area parameters"
Example:
addStripe ....  -width $wid ......  -area{100 200 500 1000}......              is OK
but
addStripe ....    -width $wid  ...  -area{$inita $initb $initc $initd }......   doesn't work
I guess  the problem comes from the curly brackets because the $wid is applied
but the extension of the stripes is totally wrong.
Can anyone help me?
Bye
Originally posted in cdnusers.org by giohdl
    change you -area{..}
    to -area [list ${x1} $[y1} ${x2} $y{2}] should fix your problem.
    li siang
    Originally posted in cdnusers.org by lisiang
    Hi Giohdl,
    Not sure if the following can work, but worth trying as it illustrate an important property of TCL:
    addStripe .... -width $wid ... -area '$inita $initb $initc $initd "......
    Please refer to a TCL book on the amazing differences between {}, "" and [], if not you might run into this type of problem again!. Basically, anything inside {} are taken "as it is", so what TCL see is the number "$inita $initb $initc $initd" which of course is invalide. For LiSiang soluation, the [] force the TCL parser to do an "re-evaluation of the expression". For "", the tool do variable subsitation.
    Eng Han
    Originally posted in cdnusers.org by EngHan
    Your solutions are OK.
    This way any list of {coordinates} in
    Encounter commands can be replaced by variables.
    Giohdl
