  3. CTS in nanometer design
  • Subscribers 96
  • Views 15123
ellisyu
ellisyu over 17 years ago
Is there any critical guideline for CTS(clock tree synthesis) in 65/45 nm design?
Wider width? Shielding?
Thank you!!
  • rtl2gds
    rtl2gds over 17 years ago
    Some of the factors to consider include: NDR rules from fab vendor (usually in tech file) Coarseness of the power-grid Availability of routing tracks Congestion with single-shielding vs. double-shielding vs. wide-wires vs. double-wide spacing Availability of balanced buffers/inverters Flavors of high drive-strength balanced buffers/inverters Via-generation requirements (single-via vs. double-via vs. via-array) based on the type of clock-routing Capability to consistently add special via-arrays for clock routes ...among other things
  • frankz
    frankz over 17 years ago
     double width and double space for clock nets are enough. Just make sure the clock tree has reasonable level and insertion delay.
